Configures the priority for the segment.
| segment-name | An alpha numeric string identifying the segment name. |
| dot1p_priority | Priority value that is set in the DMM/DMR. The range is 0 to 7. |
The default is 6.
Use this command to configure the dot1p priority that a DMM/DMR frame can get.
The following example configures a dot1p priority of 3 for segment s2.
configure cfm segment s2 dot1p 3
This command was first available in ExtremeXOS 12.3.
